Login
YoutubeInstagramRSSGithubPatreonPrivacy
Fixt β€’ Β© 2025
Updated: Oct 1, 2024β€”5 min read
Easiest way to Control your Smart Home with AI: Ollama + Home Assistant
PrerequisitesHome 3B v3Home 3B v2Activate WSL Server ModeAutomate Script Execution at LogonLlama Conversation IntegrationRemember to update
Ollama Icon
  • Working Ollama Installation
Home 3B v3
This new version is based on StableLM-Zephyr-3B, it achieves a score of 97.11% score for JSON function calling accuracy on the test dataset it’s trained
This version supports blind, light, garage_door, media_player, fan, lock, climate, switch, vacuum, todo, input_select and timer entity types.
And now with multi-language support: English, German, Spanish and French
fixt/home-3b-v3:TAG
NameTAGBitsSizeMax RAM requiredUse Case
Home-3B-v3.q2_k.ggufQ2_K21.08 GB3.50 GBsmallest, significant quality loss - not recommended for most purposes
Home-3B-v3.q3_k_m.ggufQ3_K_M31.39 GB3.89 GBvery small, high quality loss
Home-3B-v3.q4_k_m.ggufQ4_K_M41.71 GB4.21 GBmedium, balanced quality - recommended
Home-3B-v3.q5_k_m.ggufQ5_K_M51.99 GB4.49 GBlarge, very low quality loss - recommended
Home-3B-v3.q8_0.ggufQ8_082.97 GB5.47 GBvery large, extremely low quality loss - not recommended
Use the button below to go to the Integrations Page
To use this version, click on Configure and on Prompt Format select Zephyr
Home 3B v2
fixt/home-3b-v2:TAG
home-3b-v2.q2_k.ggufq2_k21.11 GB3.67 GBsmallest, significant quality loss - not recommended for most purposes
home-3b-v2.q3_k_m.ggufq3_k_m31.43 GB3.98 GBvery small, high quality loss
home-3b-v2.q4_k_m.ggufq4_k_m41.74 GB4.29 GBmedium, balanced quality - recommended
home-3b-v2.q5_k_m.ggufq5_k_m52.00 GB4.57 GBlarge, very low quality loss - recommended
home-3b-v2.q8_0.ggufq8_082.96 GB5.46 GBvery large, extremely low quality loss - not recommended
The above RAM figures assume no GPU offloading. If layers are offloaded to the GPU, this will reduce RAM usage and use VRAM instead.
WSLPorts is a PowerShell script that allows you to easily redirect and open ports in the Windows Firewall for your WSL Services.
It also prevents Windows from shuttting down WSL so you don't have to keep a Terminal Open
Save it on C:\WSLPorts\WSLPorts.ps1
$a = New-ScheduledTaskAction -Execute "powershell.exe" -Argument "-ExecutionPolicy Bypass -WindowStyle Hidden -File `"C:\WSLPorts\WSLPorts.ps1`" "
$t = New-ScheduledTaskTrigger -AtLogon
$s = New-ScheduledTaskSettingsSet -AllowStartIfOnBatteries -DontStopIfGoingOnBatteries
$p = New-ScheduledTaskPrincipal -GroupId "BUILTIN\Administrators" -RunLevel Highest
Register-ScheduledTask -TaskName "WSLPorts" -Action $a -Trigger $t -Settings $s -Principal $p
Based on this article
By acon96
v0.2.5 is out
If you installed v0.2.4, you need to set max tokens to 128 (or your preferred value) in the configuration after the update
Remember to update
to update it
docker compose pull
docker compose up --force-recreate -d
